Hello Guest it is November 10, 2026, 01:53:42 AM
Author Topic: Param1 Function  (Read 6498 times)
Param1 Function
« on: July 22, 2015, 10:34:06 PM »
Hi Mach users,
I'm having troubles under standing how the Param1 -3 work, and how the VB/CB Script layout should be to make it function properly
Here's what I'm tiring to accomplish I have a macro named M143.m1s and I want to return a P value for a second spindle RPM  sent to  OemDRO 2005
Macro Name in is M143.m1s the code I use in the MDI line is M143 P1500, and a 0 is returned
Dim Paarm1 As Double
Dim S2RPM As Double
S2RPM = Param1()
SetOemDRO(2005,S2RPM)
End
Thanks Adam
Adam
Re: Param1 Function
« Reply #1 on: July 22, 2015, 11:31:11 PM »
Dim S2RPM As Double
S2RPM = Param1()
End
