Hello Guest it is November 12, 2026, 09:19:07 AM
Author Topic: Newbie trying to get Mach3 running as a simple 2.5D engraver  (Read 10751 times)
Offline ecm
  •  3 3
« on: April 29, 2007, 09:17:24 PM »
Got Mach 3 running based on the 'milling' macros. It's running X & Y just fine. Have set up Z as simple up & down ("2.5D" option set). In testing when Z is 0, the heads up. When any other value the head drops. Therefore seems to be working fine. But when trying to actually run a job, it makes multiple passes.
I'm importing a simple HPGL text graphic through LazyCam. You can see the generated Z code is making multiple passes at multiple depths rather then the simple "drop the head and make one pass".
Question ... how do I get Mach 3 to operate the Z axis as a simple up/down?
Thx ...
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Newbie trying to get Mach3 running as a simple 2.5D engraver
« Reply #1 on: April 30, 2007, 12:30:50 AM »
Hi, Ecm
Post your HPGL & Tap files, will look at it.
In LazyCam, Bottom right, Under Selected Layer, The  PassDepth (1.000) needs to be larger than CutDepth (-0.500) or Lcam will generate multi-cut path's.
If you have a center mouse wheel, Press it down in LC screen and move it you'll se the cut depth or multi-cut's.
Maybe that's It, Chip
Offline ecm
  •  3 3
« Reply #2 on: April 30, 2007, 09:40:32 AM »
Great! Thanks. It worked perfectly! I'm on to fine tuning cutter, etc. Thanks again for your help!!!
