Hello Guest it is October 24, 2026, 02:50:34 PM
Author Topic: need help with script  (Read 11118 times)
« on: July 14, 2015, 06:22:48 AM »
i have this code in the signal script,
if (sig == mc.ISIG_INPUT1) and (state == 1) then
mc.mcCntlCycleStart(inst)
end
but what if i have two inputs
something like this  :
 if ((sig == mc.ISIG_INPUT1) and (state == 1)) and ((sig == mc.ISIG_INPUT10) and (state == 1))
end
how do i do that ?
Re: need help with script
« Reply #1 on: July 14, 2015, 01:23:27 PM »
Code: [Select]
local Input1 = 0;
local Input10 = 0;
local hSig = 0;
hSig = mc.mcSignalGetHandle(inst, mc.ISIG_INPUT1);
Input1 = mc.mcSignalGetState(hSig);
hSig = mc.mcSignalGetHandle(inst, mc.ISIG_INPUT10);
Input10 = mc.mcSignalGetState(hSig);
if (Input1 and Input10 and (state ==1)) then
    local inst = mc.mcGetInstance();
    mc.mcCntlCycleStart(inst);
end
--Scott
« Reply #2 on: July 15, 2015, 08:14:50 AM »
thank you its working :))
« Reply #3 on: July 15, 2015, 09:06:40 AM »
BTW , can i use this method in a sig table also ?
Offline dude1
  •  1,253 1,253
« Reply #4 on: July 15, 2015, 04:02:30 PM »
yes but it`s a little bit different look in the mach 4 scripting manual it under manuals on mach web site
« Reply #5 on: August 31, 2015, 02:50:18 PM »
Found out that the piece of script from poppabear isn't working as intended. If you only activate one of either inputs the task wil already be executed.
the correct way to do this is.
local Input1 = 0;
local Input10 = 0;
local hSig = 0;
if ((Input1 == 1) and (Input10 ==1)) then
end
I hope it is to some use.
Marco.
end
