Hello Guest it is October 23, 2026, 05:23:23 AM
Author Topic: Free G76 Macro Helping program for Mach3 Turn  (Read 302276 times)
Re: Free G76 Macro Helping program for Mach3 Turn
« Reply #60 on: February 28, 2020, 06:08:58 PM »
Hi Stephan! Today I managed to do some real tests with your macro and thread helper! In plastic yet...
But the 3/4 16 TPI thread I tested (not the fine one, the other one) worked perfectly and fit my bolt in the first attempt. I’ll test in brass over the weekend.
A doubt: I chose Z = 0 as the start and Z= 6 (-6) as the end of an external thread.
It begins the thread at 5.17 (or something like it) and stops before the -6. I had to make it to -7.5 to actually get to -6 in Z
The clearence in Z is 0.2mm
My settings are metric, Z-, 0.2 in clearence in x and z, parallel port for now...
« Reply #61 on: February 29, 2020, 02:51:54 AM »
It should have the -6 at the very end of the pullout. I did that to prevent collisions if you have a tiered bolt (and it was so originally). So if you have 360 degrees pullout, you have to add a full pitch to get the length of full thread you want.
The 5 - something is around three pitches run-up to stabilize the sync between spindle and Z-axis. The parallel port takes longer to stabilize than the Smoothstepper, so i made that an option (smoothstepper is one pitch plus clearance).
« Last Edit: February 29, 2020, 02:54:16 AM by stephanbrunker »
