Hello Guest it is November 13, 2026, 09:45:33 AM
Author Topic: Can I make a script that only allows the tool changer to move in ONE direction?  (Read 8267 times)
Offline mike^3
  •  116 116
Hello, here is a sample script
 If GetSelectedTool = 1 Then
  Code "G53 G0 A0"
 Code "G53 G0 A-5"
 Code"G92 A0"
 While IsMoving()
 Wend
 End If
However, I only want the tool changer that I have (8 station) to rotate in ONE direction, positive, not negative. Where it stands right now it will rotate to the g0 a0. I would like for it to go forward until it goes to the tool no matter where (360 degrees) it is at. Forward direction only, is this possible?
Thanks!
YES check your email
