Hello Guest it is November 13, 2026, 12:57:08 PM
Author Topic: Need confirmation  (Read 25029 times)
Re: Need confirmation
« Reply #10 on: July 03, 2015, 09:21:10 PM »
OK I took it out of the wizard to a MAch3 page , still there
I took it back to V.022 , Still there
I even changed out the INC dro with a user dro just to make sure(;-) , Still there
I even added extra wait state time for DRO updates  JUST to make sure, Still there
G01 moves are perfect
G31 moves are munched
I even reversed the G01/G31 in the order of execution in the script and the problem followed the G31.
That will explain the problem people have had with the TLO routines not repeating.
« Last Edit: July 03, 2015, 09:24:09 PM by BR549 »
« Reply #11 on: July 03, 2015, 09:35:13 PM »
Thanks TP, not what I wanted to here, but it does confirm my thoughts. I'm using .67 and .66 Versions.
So do we live with this or submit a bug report?
Wes
« Reply #12 on: July 03, 2015, 09:55:36 PM »
As far AS I remember said there is to be ZERO mach3 fixes. But if the bug holds up that makes the G31 just about useless.
I will do more testing JUST to make sure. But it sure LOOKS like a big old bug from here.
Just to be sure it needs to be tested from a tripped point perspective NOT just an end of travel issue. IT MAY NOT even effect the trip point values as they have always been dead on accurate.  BUT you won't know until it is tested from THAT perspective as well. THAT would be the really important test. IF that is munched oh well.
« Last Edit: July 03, 2015, 10:00:12 PM by BR549 »
« Reply #13 on: July 03, 2015, 10:53:01 PM »
Wes I don' think this is a problem I had to think back a long time ago Art had said there is a MINIMUM move distance for the G31 to be accurate. I recall the number being about .050" before a trip.
(;-) Mach4 HAS the same problem with micro G31 moves I just tested it as well.
I will dig into the old test notes to see if I can find the conversation with Art.
« Reply #14 on: July 03, 2015, 10:56:49 PM »
WES the Minimum move distance is .010"  .
« Reply #15 on: July 03, 2015, 11:16:58 PM »
Thanks TP, I'll make all my moves greater then 0.254mm and try that.
I am assuming thats 10 Thousands of an inch.
Wes
« Reply #16 on: July 03, 2015, 11:28:31 PM »
Hi TP.
still getting the 1 Step loss on the G31 however above 0.254 the steps at least are working.
G31Y Test Jog# 0.208333333
Ydro: 0.20625 Ypnt: 0.20625 Jog value: 0.208333333
Ydro: 0.41458333333333 Ypnt: 0.41458333333333 Jog value: 0.416666666
Ydro: 0.62291666666667 Ypnt: 0.62291666666667 Jog value: 0.624999999
Ydro: 0.83125 Ypnt: 0.83125 Jog value: 0.833333332
Ydro: 1.0395833333333 Ypnt: 1.0395833333333 Jog value: 1.041666665
Ydro: 1.2479166666667 Ypnt: 1.2479166666667 Jog value: 1.249999998
Ydro: 1.45625 Ypnt: 1.45625 Jog value: 1.458333331
Ydro: 1.6645833333333 Ypnt: 1.6645833333333 Jog value: 1.666666664
Ydro: 1.8729166666667 Ypnt: 1.8729166666667 Jog value: 1.874999997
Ydro: 2.08125 Ypnt: 2.08125 Jog value: 2.08333333
Ydro: 2.2895833333333 Ypnt: 2.2895833333333 Jog value: 2.291666663
G01 Y Test Jog# 0.208333333
Ydro: 0.20833333333333 Jog Value: 0.208333333
Ydro: 0.41666666666667 Jog Value: 0.416666666
Ydro: 0.625 Jog Value: 0.624999999
Ydro: 0.83333333333333 Jog Value: 0.833333332
Ydro: 1.0416666666667 Jog Value: 1.041666665
Ydro: 1.25 Jog Value: 1.249999998
Ydro: 1.4583333333333 Jog Value: 1.458333331
Ydro: 1.6666666666667 Jog Value: 1.666666664
Ydro: 1.875 Jog Value: 1.874999997
Ydro: 2.0833333333333 Jog Value: 2.08333333
Ydro: 2.2916666666667 Jog Value: 2.291666663
G31Y Test Jog# 0.25416666666667
Ydro: 0.25416666666667 Ypnt: 0.25416666666667 Jog value: 0.25416666666667
Ydro: 0.50625 Ypnt: 0.50625 Jog value: 0.50833333333333
Ydro: 0.7625 Ypnt: 0.7625 Jog value: 0.7625
Ydro: 1.0166666666667 Ypnt: 1.0166666666667 Jog value: 1.0166666666667
Ydro: 1.26875 Ypnt: 1.26875 Jog value: 1.2708333333333
Ydro: 1.525 Ypnt: 1.525 Jog value: 1.525
Ydro: 1.7791666666667 Ypnt: 1.7791666666667 Jog value: 1.7791666666667
Ydro: 2.03125 Ypnt: 2.03125 Jog value: 2.0333333333333
Ydro: 2.2875 Ypnt: 2.2875 Jog value: 2.2875
Ydro: 2.5416666666667 Ypnt: 2.5416666666667 Jog value: 2.5416666666667
Ydro: 2.79375 Ypnt: 2.79375 Jog value: 2.7958333333333
G01 Y Test Jog# 0.25416666666667
Ydro: 0.25416666666667 Jog Value: 0.25416666666667
Ydro: 0.50833333333333 Jog Value: 0.50833333333333
Ydro: 0.7625 Jog Value: 0.7625
Ydro: 1.0166666666667 Jog Value: 1.0166666666667
Ydro: 1.2708333333333 Jog Value: 1.2708333333333
Ydro: 1.525 Jog Value: 1.525
Ydro: 1.7791666666667 Jog Value: 1.7791666666667
Ydro: 2.0333333333333 Jog Value: 2.0333333333333
Ydro: 2.2875 Jog Value: 2.2875
Ydro: 2.5416666666667 Jog Value: 2.5416666666667
Ydro: 2.7958333333333 Jog Value: 2.7958333333333
G31Y Test Jog# 0.504166666666
Ydro: 0.50208333333333 Ypnt: 0.50208333333333 Jog value: 0.504166666666
Ydro: 1.00625 Ypnt: 1.00625 Jog value: 1.008333333332
Ydro: 1.5104166666667 Ypnt: 1.5104166666667 Jog value: 1.512499999998
Ydro: 2.0145833333333 Ypnt: 2.0145833333333 Jog value: 2.016666666664
Ydro: 2.51875 Ypnt: 2.51875 Jog value: 2.52083333333
Ydro: 3.0229166666667 Ypnt: 3.0229166666667 Jog value: 3.024999999996
Ydro: 3.5270833333333 Ypnt: 3.5270833333333 Jog value: 3.529166666662
Ydro: 4.03125 Ypnt: 4.03125 Jog value: 4.033333333328
Ydro: 4.5354166666667 Ypnt: 4.5354166666667 Jog value: 4.537499999994
Ydro: 5.0395833333333 Ypnt: 5.0395833333333 Jog value: 5.04166666666
Ydro: 5.54375 Ypnt: 5.54375 Jog value: 5.545833333326
G01 Y Test Jog# 0.504166666666
Ydro: 0.50416666666667 Jog Value: 0.504166666666
Ydro: 1.0083333333333 Jog Value: 1.008333333332
Ydro: 1.5125 Jog Value: 1.512499999998
Ydro: 2.0166666666667 Jog Value: 2.016666666664
Ydro: 2.5208333333333 Jog Value: 2.52083333333
Ydro: 3.025 Jog Value: 3.024999999996
Ydro: 3.5291666666667 Jog Value: 3.529166666662
Ydro: 4.0333333333333 Jog Value: 4.033333333328
Ydro: 4.5375 Jog Value: 4.537499999994
Ydro: 5.0416666666667 Jog Value: 5.04166666666
Ydro: 5.5458333333333 Jog Value: 5.545833333326
Wes
« Reply #17 on: July 04, 2015, 10:01:51 AM »
Wes have you tried a Trip value test ? Set up a stop block and do the same G31 routine into the block.
DON'T run the G01 routine though (;-) Crunch.
(;-)TP
