Hello Guest it is November 23, 2026, 12:29:34 AM
Author Topic: Move buttons on the Jog tab  (Read 7549 times)
Offline Pedio
  •  200 200
« on: June 29, 2015, 01:03:58 PM »
I have been playing with the UI and I must say it is COOL!
My question is how do I move buttons on the Jog tab? I can change them on the main tab but when I try to change them on the Jog tab it thinks I am editing the entire Jog window. Sorry if this is a newby questions. If someone can point me at a "Dummies" guide for programming Mach4 I promise I will read it (comprehending may be another issue)
Re: Move buttons on the Jog tab
« Reply #1 on: June 29, 2015, 02:40:43 PM »
go to the list on the left and highlight what you want to move.... I have found for me it's much easier to put in the numbers for the height width and location.... rather than trying to move stuff with the mouse but highlighting  it in the list should work either way.
Offline Pedio
  •  200 200
« Reply #2 on: June 29, 2015, 06:19:20 PM »
I still can't edit the screen directly. When I click in the Jog window it jumps back to the operations on the left side.
The manual editing worked!    ;D
Thanks Patton. If you can get me your address I will send you a round TUIT. You can use these to get all of your objectionable projects done. The help is appreciated.
