Hello Guest it is November 24, 2026, 01:23:35 PM
Author Topic: Spindle Speed  (Read 10117 times)
Offline Ben
  •  79 79
Spindle Speed
« on: June 28, 2015, 08:34:09 PM »
Does anyone have a schematic for a 110VDC  20A speed controller that is compatable with Mach3 or where I can buy one for under $50.  Now I'm using a Nordictrack  treadmill controller and don't know how to connect it to Mach3. Ben
Offline Ben
  •  79 79
Re: Spindle Speed
« Reply #1 on: July 04, 2015, 05:58:19 PM »
Now I have a controller (U-MC-2100-WA) that accepts a pwm signal. How do I set the pwm output pin. The docs talk
about everything but how to set the pin number. Then I assume that I put that number in the Port & Pins-Motor Outputs
-"step pin #"  box for A axis(unused).  A axis step on the BOB  will be connected to the pwm input pin of the controller. Ben
Re: Spindle Speed
« Reply #2 on: July 05, 2015, 03:22:04 PM »
Use the spindle not the a axis. Look for spindle in motor outputs and in spindle setup both under ports and pins.
Don
Offline Ben
  •  79 79
Re: Spindle Speed
« Reply #3 on: July 06, 2015, 10:57:29 PM »
Thanks Don. The problem is I have a Sound Logic BOB and it dosn't have a spindle output connection. I thought I could send the pwm signal through the Aaxis step connector since I don't use Aaxis. I have mach3 running the spindle using M3 and shutting down with M5 but no pmw. I enabled the Spindle in Ports & Pins>Motor Outputs, step pin #16 ,dir 0 and Aaxis step pin #16 dir 0.  The stuff in Ports & Pins>Spindle Setup>Motor Contron Use Spindle and  pwm checked, Freq=100  min=10. Ben
