Hello Guest it is November 13, 2026, 02:02:24 PM
Author Topic: Question about simulation  (Read 23075 times)
Re: Question about simulation
« Reply #10 on: June 30, 2015, 12:00:11 AM »
IF you had an MPG you might be able to pull it it off in Mach3 using Shuttle mode.
« Reply #11 on: June 30, 2015, 12:02:08 AM »
missfired
Offline JC
  •  6 6
« Reply #12 on: June 30, 2015, 11:53:14 AM »
 if I run down to a point close to where I want to stop I can pause the program and then drag the feed override bar all the way to the bottom speed and with a well timed mouse click I can usually stop the action within a couple of thousandths of a point I want to reference but it's tedious.
I ended up just drawing a chart in Excel that gives me the exact coordinate of X for every possible position of Y to the tenth of an inch.  I can refer to it when I need to tweak my code and for my purposes that's fine.  I just thought mach3 may have the ingrained capability and I just wasn't seeing it.
JC
« Reply #13 on: June 30, 2015, 02:34:41 PM »
You could modify the code by adding a G4 in the code, but , that still doesn't do what you want.
Other than a spread sheet, backplot the code and measure in CAD as that can be anywhere you want and
as accurate as you wish.
« Reply #14 on: July 17, 2015, 02:52:32 PM »
I'm super new also.  I'm just winging it!  What gcode program are you using?
