Hello Guest it is November 22, 2026, 07:43:08 AM
Author Topic: auto tool zero with limit switch  (Read 9072 times)
« on: June 28, 2015, 06:50:53 AM »
my machine came with 5 switches and i am only using 3.  I have seen many people setup a touch plate with wire and ground.  i was wondering if it was possible to just use one of the limit switches for this purpose.  Rig up the switch with a plate on top and set it under the tool and run the auto tool zero script.  Wont that work?
Re: auto tool zero with limit switch
« Reply #1 on: June 28, 2015, 10:05:51 AM »
I doubt very accurately. There has to be a couple thou variation in the switch especially if the speed varies.
Don
« Reply #2 on: June 28, 2015, 12:05:09 PM »
IF using the G31 call to find the plate/switch speed has NOTHING to do with it. HomingG28.1 yes,  probingG31 no. It is best to use a simple contact switch not a snap switch.
