Hello Guest it is November 22, 2026, 06:53:15 AM
Author Topic: G28.1 with very long axis  (Read 8718 times)
« on: June 25, 2015, 11:13:05 AM »
Hello,
I have a very long axis and I need to use a G28.1 command to find the zero ( a precision mechanical switch ) .
If I use a low speed return to zero the cycle is very long but the precision is very goog.
If I use an high speed return to zero I have a very low precision in zero procedure.
I need to find the zero with an high speed in the first step of cycle and after to find the zero with a low speed procedure.
Have you an idea to switch the speed on the fly with a G28.1 command ?
Thank you for Help.
Re: G28.1 with very long axis
« Reply #1 on: June 25, 2015, 01:13:35 PM »
« Last Edit: June 25, 2015, 01:38:30 PM by Overloaded »
