Hello Guest it is November 22, 2026, 07:18:43 AM
Author Topic: Mach 3 mill versus profile mill Errors..  (Read 9431 times)
« on: June 24, 2015, 04:53:36 PM »
I am new to this so I do not speak CNC well, and was at a loss as to how to search it.\
I have a licensed copy of Mach 3, I also use a profile as the installer said I should. I use heeks 1.1 to make the g code for the models.
When I load my Gcode into the Mill Profile, its all screwed up. When I use the default MachMill profile it loads fine. I have not cut it yet as I have to set my mill up under that profile. I also feel this must have happened to someone and I hate to post for nothing but, anybody got a simple fix or anything aside from what I am doing.
Matt
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Mach 3 mill versus profile mill Errors..
« Reply #1 on: June 24, 2015, 05:06:05 PM »
it could be the INC IJ in the config that is set the wrong way round for your code, try changing it.
« Reply #2 on: June 24, 2015, 05:36:21 PM »
Where can I find it and how can I change it.
Matt
« Reply #3 on: June 24, 2015, 06:40:29 PM »
I found it, I'll try that. What is it?
Thanks'
Matt
