Hello Guest it is November 22, 2026, 07:10:58 AM
Author Topic: Step/port frequency  (Read 9867 times)
Offline Davek0974
  •  2,606 2,606
Step/port frequency
« on: June 23, 2015, 11:09:45 AM »
Step frequency?
I need to drive a machine driven by two steppers at 9000mm/min using ballscrews, direct drive.
Is it as simple as...
9000mm/min with 20mm lead screw so 9000/20=450rpm
450*200 steps per rev=90,000 steps or pulses per min
90,000 / 60 = 1500 steps per second
so max frequency per axis is 1.5kHz ?????
Using 10x micro stepping would need 15kHz per axis?
If so would that be safe if my port is happy at 50kHz????
Many thanks
Offline Davek0974
  •  2,606 2,606
Re: Step/port frequency
« Reply #1 on: June 25, 2015, 03:36:34 AM »
Anyone???
« Reply #2 on: June 25, 2015, 05:53:48 AM »
Should be fine but you may want to use 25kHz as the Kernel Speed.
Offline Davek0974
  •  2,606 2,606
« Reply #3 on: June 25, 2015, 08:14:36 AM »
Thanks, I did wonder why that was set at 50k - It changed when I installed the CandCNC MP3000-DTHCII unit and custom screen sets, I know they do some pretty funky stuff with the port, maybe thats the reason.
It passes the port test ok and has been running at 50kHz for about 9 months now so probably safest to stick with it, unless there is a good reason no to?
Might ask Tom at CandCNC.
