Hello Guest it is November 22, 2026, 07:19:04 AM
Author Topic: Pendant Setup with C32 BOB  (Read 7686 times)
« on: June 22, 2015, 07:20:23 PM »
One last thing to get my new machine working and complete......The Pendant
Mach3
CNC4PC C32 BOB
Standard MPG using DB25
Got the pendant working on a limited basis. No matter what position the switches on the pendant are set to, the X axis moves. Also, the distance for each click is the same regardless if it is set on 1, 10, or 100. I know that the system is seeing the pulses because on the Settings page under the MPG area the velocity and count moves whenever I rotate the pulser.
What would you suggest I look at or maybe some screen shots of your setup if you think it will help.
needonemoretool
Re: Pendant Setup with C32 BOB
« Reply #1 on: June 28, 2015, 10:08:40 AM »
Did you add the brians from the directions from cnc4pc? Or use th plugin?
Don
« Last Edit: June 28, 2015, 10:10:15 AM by DonMarkey »
