Hello Guest it is November 20, 2026, 08:15:06 PM
Author Topic: diameter compensation  (Read 9057 times)
Offline amnon
  •  40 40
« on: June 17, 2015, 12:54:55 PM »
Hej,
I don't know why doesn't work diameter compensation  in my code(some part below).
Code: [Select]
M01
N3 M6 T3
(TOOL -3- MILL DIA 8.0 R0. MM )
G90 G00 G40 G54
G43 H3 D33 G0 X68.999 Y-15. Z50. S1000 M3
M8
(ROZFREZOWANIE OTWORU FI 11 - PROFILE)
   X68.999 Y-15. Z20.
   Z2.
G1 Z-0.3 F33
G41 G1 X73. F100
G3 X73. Y-15. I-5.5 J0.
G40 G1 X68.999
   Z-0.6 F33
G41 G1 X73. F100
G40 G1 X68.999
   Z-0.9 F33
G41 G1 X73. F100
G40 G1 X68.999
   Z-1.2 F33
G41 G1 X73. F100
G40 G1 X68.999
   Z-1.5 F33
G41 G1 X73. F100
G40 G1 X68.999
   Z-1.8 F33
G41 G1 X73. F100
G40 G1 X68.999
   Z-2.1 F33
G41 G1 X73. F100
G40 G1 X68.999
   Z-2.4 F33
G41 G1 X73. F100
G40 G1 X68.999
   Z-2.7 F33
G41 G1 X73. F100
G40 G1 X68.999
   Z-3. F33
Respect
Amnon
Re: diameter compensation
« Reply #1 on: June 17, 2015, 04:18:34 PM »
First the 01 is an invalid word. to name it it must use the o1 word not a ZERO 1
You are calling to USE tool #3  M6T3
BUT you are calling the COMP to use tool#33  D33.
Also there is really no reason to comp each and every move down through the helix Just comp it at the beginning and remove at the end . IF you are doing it to get a smooth transition then just program a small circle coming out of the circle end move and back into the beginning move. During that small transition move lower the Z to the next cut step. It makes it much faster and just as smooth running/cutting
Offline amnon
  •  40 40
« Reply #2 on: June 19, 2015, 07:34:41 AM »
Hej,
Thanks a lot, I removed D33 and works fine.
Maybe you know how to do this in Solid Cam
Amnon
