Hello Guest it is November 22, 2026, 08:46:15 AM
Author Topic: What is the min movement I can command in mach3?  (Read 12235 times)
« on: June 14, 2015, 11:04:33 AM »
Assuming i have a very hefty reduction (10tpi screw, 10:1 belt reduction) how small of an increment can mach 3 be commanded to move. Will it accept a .00001" command in the mdi dro?
Re: What is the min movement I can command in mach3?
« Reply #1 on: June 14, 2015, 12:56:30 PM »
natefoereg,
It all depends on your steps per uinit. The min resolution  would be 1/steps per unit and
most machines will not accurately move to the theoretical min resolution.
IE; My engraving machine has 253000 steps per unit, thus the smallest resolution would be
0.000004", but , the "machines system" requires the capability to be able to move that small,
and, one needs to be able to measure the movement.
To measure your 0.000010 movement would require a calibrated scale ( about $1000 ) and around
a 600 to 900x quality microscope. I doubt very much a belt reduction is any good for that kind movement.
FWIW,
« Reply #2 on: June 14, 2015, 01:08:35 PM »
I am really asking if I can even input a command into mach 3 for a movement as small as .00001"
I have electronic indicators with amplifiers, 20 millionth mechanical indicators, Mahr/federal electronic levels etc.. I can measure very small movements as well as anyone can in a non temp controlled setting.
I am interested in retrofitting a machine (Moore Jig Grinder) that has lead screws that are more accurate than most micrometers.
Assuming I have the appropriate reduction, can mach 3 accept and implement a command for a movement as small as .00001"?
I know that their are MANY real world problems with making and measuring a move of only ten millionths. I only want to know (assuming a zero backlash system with a large reduction) can mach accept, understand and implement a move as small as .00001"?
« Reply #3 on: June 14, 2015, 01:47:02 PM »
You will have to change the resolution of the DROS in Mach3 (easy)  but yes you can call any move that equals to 1 step of the drive . Mach3's DISPLAY WILL round the last decimal place UP SO for .00001 you would set the dros for .000000 or the min Plus 1 decimal point.
BUT if you quiry the DRO through script you WILL get the Raw number which may be as long as 13 decimals
« Last Edit: June 14, 2015, 01:49:03 PM by BR549 »
« Reply #4 on: June 14, 2015, 02:27:17 PM »
Thanks everyone!
« Reply #5 on: June 15, 2015, 04:27:24 PM »
Unless the machine has very low stiction/friction, I suspect that you would be very lucky if the stepper or servo could move by such a small amount even though Mach might deliver it the requisite pulses.  This because the incremental torque generated would be too small to move the axis or even the screw.
Sent from my iPad using Tapatalk
