Hello Guest it is November 18, 2026, 12:44:53 PM
Author Topic: ESS Mounting Case  (Read 11111 times)
Offline $cott
  •  36 36
ESS Mounting Case
« on: June 12, 2015, 12:08:27 PM »
I had no way of mounting my ESS board effectively and both connect from my PC and interface to the ports so I designed a case for it and printed it on my BOT. Worked out nice protects everything and I can get to all the connections.  It can be mounted on 3 sides.  I used the face in my application so I could interface to it directly from my PC.  Attached is 3D PDF so it can be seen in detail.
Scott
