Hello Guest it is October 24, 2026, 10:49:29 AM
Author Topic: Mach4 seems to lose connection to darwin  (Read 10480 times)
« on: June 11, 2015, 05:46:21 AM »
Hi to all,
I have a problem with Mach4 and Darwin- after a random time (5~10 Minutes) Mach4 don't react on any external inputs of my Darwin interface.
I thought that the input script is not longer executed- so then I tried to start a job with the Mach4-Buttons on the screen.
I see the state toggling to "StartCycle" but nothing happens, too.
Some days ago I saw inside a job that Mach4 stops working. No Message, no error -
It stuck in the middle of the G-code. I tried disabling, re-enabling, reset the job- no chance!
The spindle was already running. But no further movements.
A restart of Mach4 solves this state.
I opened the Darwin interface setup- there I can see that Darwin is detecting input changes in the "error state"- but It seems that Mach4 loses the connection or control.
Any Idea? I attached the log when I try to start a job in case that mach4 stuck.
For information: In the error state there are no longer input changes written in the log and no further reaction of the regarding input LEDs in the Mach4 diag screen- only in the darwin setup itself.
For getting the error state I have only to wait - Machine on - working. Then I go for drinking a coffee - when I come back: Machine stuck  :o
Regards and thanks!
Sebastian
Re: Mach4 seems to lose connection to darwin
« Reply #1 on: June 11, 2015, 06:54:24 AM »
All Darwin questions should be posted in the main Darwin thread, where Art will see them.
« Reply #2 on: June 11, 2015, 06:59:21 AM »
Check to be sure that Mach4 has recognized your license key. The behavior
that you describe sounds somewhat like running in Demo mode.
Steve Stallings
www.PMDX.com
« Reply #3 on: June 11, 2015, 07:05:51 AM »
Thanks, I checked this.
After copying the license file to the regarding folder the "Demo"-Appendix in the title bar of Mach4 disappeared.
In addition to that I see "Licensed" in the About-Window.
« Reply #4 on: June 11, 2015, 07:12:22 AM »
To the comment of ger21 - where can I find the "Darwin main thread" ?  :)
