Hello Guest it is October 24, 2026, 08:53:30 AM
Author Topic: wxLua MP-03 Pendant kit(Peter Homann), Wizard for Mach4, in progress...  (Read 11595 times)
Well, trying to port over the plugin I did for Pete's MP-03 modbus pendant to a wxLua Wizard and screen integration for Mach4.
It can do:
MPG, Cycle Start, Estop, FSOVR, Spindle On/Off via buttons, and
27 control functions via Soft buttons, that the user can custom assign,
Plus fire off 15 macros (user or OEM), and optionally map inputs to screenset "Leds" for monitoring or other purposes.
see screen shots of wxLua Pendant config notebook.
Scott
Offline dude1
  •  1,253 1,253
well everyone else needs to catch up or higher you to do it for them
Looking good Scott, looking good!
Thanks Gents!
Made a minor mod, added text so that the user would know to only
use the Macro's Number part only for firing off macros.
Scott
The devil is in the details for sure. It makes a lot of sense to add that little bit of instruction where you did and it looks clean. If you want it to really be seen make it stand a little more. Maybe use red text?
Ok, that makes sense, and THANK YOU for the input!!
Scott
