Hello Guest it is November 22, 2026, 08:25:20 AM
Author Topic: Changing computer  (Read 9562 times)
Changing computer
« on: June 08, 2015, 12:16:26 PM »
Hi have been running mach3 on XP for 4years never any problems
Am going to put new computer onto newly built router
They all come with windows 7 or 8
Will mach 3 run ok on windows 7 or 8 ?
I think there used to be problems with vista
Colin
  •  9,378 9,378
Re: Changing computer
« Reply #1 on: June 09, 2015, 01:39:40 AM »
Hi Colin,
Just a few observations...
If you are using the parallel port then you need to have the 32 bit version of Windows 7.
Windows 8 does not support use of the parallel port.
An external motion controller will be required for 64 bit OS versions and/or Windows 8.
« Reply #2 on: June 09, 2015, 07:36:23 PM »
Hi Colin,
if your chasing Windows 7 32 bit and cant find any, try asking the computer companies(HP,Acer etc) for Windows 7 Commercial systems with parallel ports. Much better quality however most only have std video and turn of UAC otherwise you will have all sorts of bother.
Wes
