Hello Guest it is October 24, 2026, 11:43:32 AM
Author Topic: Mach 4 Logging...how do you get around this bugger?  (Read 7848 times)
« on: June 05, 2015, 11:16:55 PM »
...Can't transition from "Idle" on event "Stop"....
how do we make mach 4 transition to Idle?
sequence:
1. start movement
2. input0 changed from low to high
3. mcCntlCycleStop() called
4. Gcode running changed from high to low
5. mach_state_stop
6. S_IDLE_on_entry
6. waiting on SetStill is Done!
7. attempt transition from "MDI running" on event "stop"
8. can't transistion from "idle" on event "stop"
then it repeats last cycle.... >:(
any advice?
--josh
Re: Mach 4 Logging...how do you get around this bugger?
« Reply #1 on: June 06, 2015, 12:55:47 AM »
assert function? "I assert you!" ...yah, and m4 gives me the middle finger! I tried that with the girlfriend. DIDN'T WORK OUT!
seriously though, this is the last step I need to get by.....so close!
« Reply #2 on: June 11, 2015, 05:48:53 AM »
just wanted to say something. this error has nothing to do with Mach 4. It is my own error that was caused by me doing a work around on my limitations. (that's why I asked for help) I was trying to report messages to m4 core whereas m4 was receiving messages at the same time causing the conflict. I jut wanted to put that out there. that's all....
--j
