Hello Guest it is October 24, 2026, 04:54:42 PM
Author Topic: Keypad as a Pendant - sort off  (Read 8793 times)
« on: June 04, 2015, 11:02:57 PM »
Hi Guys
just a little something I use for my machine. A Keypad!
I have altered the Std 1024 Screenset as I don't use speeds other then Manually changing them.
On an external Num Keypad I have setup / and * as my Rapid feed plus and minus
the Home and End Keys I use for Jog Feed rate and + and - for Normal feed rate(as set by GCode).
I have included some Photos and the 1024xtg set file I use.
Wes
« Last Edit: June 04, 2015, 11:06:13 PM by ozwes007 »
Re: Keypad as a Pendant - sort off
« Reply #1 on: June 05, 2015, 06:17:52 AM »
Hold on there cowboy, that's pretty handy.
I bought one of these some time ago with the same intentions ... but never got to it.
Thank you very much !
Nice work Wes ... (again).
Russ
« Reply #2 on: June 05, 2015, 06:46:59 AM »
Your welcome Russ. Glad to be of help.
Wes
