Hello Guest it is November 13, 2026, 12:40:57 PM
Author Topic: Need Help  (Read 26079 times)
Re: Need Help
« Reply #10 on: June 05, 2015, 04:11:23 PM »
Thanks, I will try that!
Re: Need Help
« Reply #11 on: June 05, 2015, 04:19:45 PM »
Awesome, curious question. You are just wanting to plasma cut with your cnc?
Re: Need Help
« Reply #12 on: June 05, 2015, 04:23:39 PM »
yes.
Re: Need Help
« Reply #13 on: June 05, 2015, 04:29:36 PM »
Alright, that's all i am using mine for too. I am to the point now where I need to figure out how to start and stop the plasma arc.
Re: Need Help
« Reply #14 on: June 05, 2015, 04:32:01 PM »
you're way ahead of me. I think there is a button on the main screen (Run Program), that lets you start and stop the plasma.  It's kinda towards the center of the screen.
Re: Need Help
« Reply #15 on: June 05, 2015, 04:34:56 PM »
do you know how to increase the speed of the motors. I think the sample G-Code program is for a router so somewhere in the code is the speed factor.
Re: Need Help
« Reply #16 on: June 05, 2015, 04:39:02 PM »
"motor tuning" tab under "config". sorry i was misleading before when i said ports and pins. but it is under config tab and motor tuning. And you can do all the x and y axis individually
Re: Need Help
« Reply #17 on: June 05, 2015, 04:41:00 PM »
OK
Re: Need Help
« Reply #18 on: August 26, 2015, 12:00:58 PM »
I need help with the Mach3 program.  I have drawn and converted to dxf file.  I then load into LazyCam and produce G-Code.  When i load the code, it shows the proper dimensions on the DRO.  I have changed all units of measure to mm. This is where I am lost, when I start the program, it cuts larger than the original dimensions (i.e. 8mm becomes 22mm). I have calibrated the motors, plugging in 25.4mm for x and y axis and the 18.75mm resulting from movement of the x/y axis. I have no idea why it makes the cuts larger than the drawings.  Any ideas?
 I had a reply from one of the mediators to load the xml file, but i can't find the email.
