Hello Guest it is October 24, 2026, 03:49:34 AM
Author Topic: DRO for typing in feed rate  (Read 12556 times)
« on: May 29, 2015, 10:20:40 AM »
Is it possible to make a DRO for typing in feedrate?
Re: DRO for typing in feed rate
« Reply #1 on: May 29, 2015, 10:30:06 PM »
Yes.  Add a DRO, then write a script to write the DRO value to a # variable.  Use that variable in your gcode instead of a federate.   IE: F#5
« Reply #2 on: May 30, 2015, 01:38:44 AM »
that's exactly what i need, but how do i write a script, do you have a example ?
« Reply #3 on: May 30, 2015, 05:39:37 AM »
Look in the Mach4\Docs folder
« Reply #4 on: May 30, 2015, 08:07:31 AM »
You don't need a script to do this.... it can be done with the dropdown settings ...... add a dro.... set it to dro code - feedrate ...... set it to edit in place.
« Reply #5 on: May 30, 2015, 08:50:25 AM »
Correction: dro code needs to be set to feedrate override....... and of coarse it can be done with a script too but this would be an easy way to do it. it lets you click on the dro and put in a number and will set your feed rate.
« Reply #6 on: May 30, 2015, 08:13:06 PM »
I have already done this and just wrote up a quick how to for you.
https://docs.google.com/document/d/1bhJA7qsQ1zGFKvoj1mNsfEgYgSnDT35RfQJ3tgOlxl8/edit?usp=sharing
Let me know if you need anymore info, as this one is a little bit more in depth then you were asking, but it nice that it will not let you set it outside the 1-250% range which you can change and it moves the slider around
-McDaigle
