Hello Guest it is October 04, 2026, 08:07:39 AM
Author Topic: mach3 loading previous version of gcode  (Read 9315 times)
« on: May 26, 2015, 12:58:28 PM »
Today Mach found a 'new' trick; I run a gcode file, close Mach, edit the gcode file and save it, load it back into Mach, and lo! Mach has loaded up the version of the file BEFORE I made changes to it.
I'm not imagining this, its driving me ******* nuts, how do I stop it ? Is this some kind of malfunction?
M21
Re: mach3 loading previous version of gcode
« Reply #1 on: May 26, 2015, 05:46:52 PM »
Odds are good you are NOT saving to where you think you did (;-) Been there done that one a number of times. I hate the way Mach3/4 will always go to the last place you saved something NOT to the Gcode directory as it should.
« Reply #2 on: May 27, 2015, 12:16:44 AM »
Me too! I take it that can't be changed?
I did have a flash drive plugged in, and got very tired and frustrated with it yesterday, so I probably did save to the wrong place.
Good to know it doesn't only pick on me, thanks.
