Hello Guest it is October 23, 2026, 12:57:53 AM
Author Topic: Has anyone tried one of these?  (Read 12235 times)
« on: April 23, 2007, 10:33:25 PM »
    Has anyone tried one of these yet? The best I can figure it would take the place of an I-pac and using key grabber if it works. It is a programable key pad with buttons you can customize. I understand they are making a 12 key sealed industrial version as well. It has its own memory and can be programed to send any combination of keystrokes at the press of a single button. I'm not talking only three buttons either. I don't know its limits but I think you could have one key equal a paragraph if you had the need.
     If you have tried this or can give any feedback, please do.
http://www.enablemart.com/productdetail.aspx?pid=930&dept=20&store=10
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Has anyone tried one of these?
« Reply #1 on: April 24, 2007, 10:42:28 AM »
Brett,
I haven't tried the one you've link before, but I was looking at this company http://www.electronickeyboards.com/index.html , which I talked on the phone to awhile ago and it's not very expensive:
Not sure what do you think would be better?
« Reply #2 on: April 24, 2007, 11:10:48 AM »
I'm not sure. I need to call them both and see. Those look good at first glance. I like the idea of the keyboard being programmable. Seems it would make things cleaner. Thanks for the link.
« Reply #3 on: May 27, 2007, 09:29:43 AM »
Well, I saw on of these set up for a pendant. They are very neat. I think they run about $120.00. My friend says the USB model is the one to get. Here is another link. It shows more products. I think I saw a keypad, joystick combo. Is that a shuttle pro I see in the middle?
http://www.piengineering.com/xkeys.php
« Last Edit: May 27, 2007, 09:45:44 AM by Chaoticone »
« Reply #4 on: May 27, 2007, 03:41:02 PM »
I have one on my mill. It works fine, and has enough keys for all the functions I need.
 However, I also have a Genovation control Pad for my router, and like it better. It  is cheaper, but more important, the X-keys requires a special driver to be loaded. The driver reads the key code form the keypad and converts it to the string you aet.
The genovation has a download feature- you load the actual key strokes into it, it then sends those, no drivers needed. I always like not having to add special drivers that may or may not be happy with Mach.
http://www.genovation.com/
I found my genovation on ebay for about $50.
