Hello Guest it is November 10, 2026, 01:55:05 AM
Author Topic: How to use this Open Source Wizard  (Read 8250 times)
« on: May 22, 2015, 05:49:47 AM »
Hi all,
I have an open source wizard but I cant using it. Can anybody explain me how to install it?
Here is a link of the wizard with source codes
https://github.com/regeg/ArdunioTHC/tree/master/Mach%20Plugin
I already tried copying the dll file in to plugins and mach3 folder. And it doesnt work.
Thanks in advance.
Speacially thanks to everlastgenerator forum's empty nester member(regeg) for develop this project....
Re: How to use this Open Source Wizard
« Reply #1 on: May 22, 2015, 08:37:24 PM »
It's for an Ardunio project board by the looks of it.
« Reply #2 on: May 23, 2015, 12:39:48 PM »
Yes thats an arduino project but is there an anybody to help me about installing the wizard?
« Reply #3 on: May 23, 2015, 12:47:13 PM »
That is NOT a wizard it is a plugin. Best to contact the writer of the plugin for help. He will be the only one that knows how it works.
The generic way would be to install the plugin in the Mach3 plugin directory. Then shut down Mach3 and restart. It should show up in the config plugin section. Select the plugin and do any config for it there.
