Hello Guest it is October 20, 2026, 05:40:41 PM
Author Topic: Communication Mach3 external software  (Read 9715 times)
« on: May 15, 2015, 03:19:06 AM »
Hello everybody,
I am using mach 3 to control a CNC Router which will be used to verify the precision of an optical tracking system.
The workflow I hope to achieve is this:
1) CNC Router moves to position defined in the G-Code and stops.
2) Mach3 sends a signal to another software “position  was reached”.
3) Mach3 waits for a signal from the external software to start reading the next G-code line and move to a new position.
Can anyone please help me achieve this?
At the moment I am not using any external commands (Cooling, Tool exchange etc…)
I would be very happy, if anyone helps me ;D ;D
Cheers,
Mark
Re: Communication Mach3 external software
« Reply #1 on: May 15, 2015, 06:25:02 AM »
To be more specific: I don`t know how to send/receive a Signal from a external software, which is running on the same pc as the Mach3 software. I would like to do it "soft", without using a relais connected to the controller.
« Reply #2 on: September 07, 2020, 06:13:14 AM »
i am also wondering if this could be done
did you find anything?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: September 08, 2020, 09:48:20 AM »
You can put a pokeys on and check signals from that with the plugin.
