Hello Guest it is November 13, 2026, 12:40:08 PM
Author Topic: Looking to purchase compete setup - will this do?  (Read 12020 times)
« on: May 14, 2015, 11:14:26 AM »
Good morning,
I'm looking to update some of the CNC gear I have (that I can't get working :( ) on my mill.
I was looking at this on Amazon:
http://www.amazon.com/TB6560AHQ-Stepper-Motor-NEMA23-Supply/dp/B00J21FVDY/ref=sr_1_32?ie=UTF8&qid=1431619761&sr=8-32&keywords=cnc+controller+mach
That says it works with Mach.
Does a kit like this contain everything needed? Looks like there's a controller board, a power supply and the steppers. I actually don't need the steppers, but don't mind having a few extras on hand.
If this is not a good option, can someone suggest a better one?
Greg
Re: Looking to purchase compete setup - will this do?
« Reply #1 on: May 14, 2015, 12:04:51 PM »
I would stay away from this kit.
Buy separate drivers for the motor and a 48v power supply, at least 10amp.
Jeff
« Reply #3 on: May 14, 2015, 12:20:44 PM »
The 6560 amplifier chip is obsolete, and has been replaced by the TB6600,
There are newer models of this single board system with the TB6600 driver, that incorporate a huge heatsink that is the entire bottom of the board. It also has more efficient 5v, and 12v voltage regulators built in for spindle control, 0-10v output with a separate spindle P.S.
Also, it has reduced the number of components, and is USB connected to the computer. For a small system, keeping power output under 4amps, @36v, it is a nice package. However, it you intend to push the amps hard with bigger motors, building a system with separate amps would be advisable, as pointed out.
The single board unit will result in a small system, with a minimum of wires. I have built both kinds of systems.
John
« Reply #4 on: May 14, 2015, 03:17:16 PM »
What kind of mill do you have?
« Reply #5 on: May 14, 2015, 03:21:06 PM »
Small Central Machinery (Harbor Freight) Bench Top.
This one:
http://www.harborfreight.com/two-speed-variable-bench-mill-drill-machine-44991.html
Already outfitted with steppers.
Greg
