Hello Guest it is October 21, 2026, 12:10:00 AM
Author Topic: How to pause movement for a specific amount of time  (Read 9256 times)
« on: May 11, 2015, 05:18:37 AM »
Hello,
I am using the Mach3 software to control the movement of a CNC machine and I am trying to find a way to pause the movement of the XYZ axis for a specific amount of time, let's say 1 minute, and then start again. Below are some details that might help you with your answer:
I am using a extrusion/dispensing system that is attached on the CNC machine to print ceramic pastes in order to create 3D structures in a layer-by-layer manner (3D printing) and i would like to pause the printing process for 1 minute after each layer in order to allow the ceramic paste to dry before i carry on printing the next layer on top of the previous one.
Is there any way to do that within the G-code or on the Mach3 software?
Thank you
« Last Edit: May 11, 2015, 05:24:10 AM by AMRG »
Re: How to pause movement for a specific amount of time
« Reply #1 on: May 11, 2015, 05:44:28 AM »
Consider using the G4 dwell command.
« Reply #2 on: May 11, 2015, 06:01:33 AM »
Thanks! i was not aware of this command
