Hello Guest it is November 22, 2026, 11:27:39 PM
Author Topic: Home Setting on X axis creeping..  (Read 8909 times)
« on: May 05, 2015, 06:25:09 PM »
I am very new to all this but have made it this far at least...
I have a 3040 Router that all seems to be setup and working ok..
I got my home settings done, calibrated the movements etc..
I tried to just do a "skim" across my sacrificial base and as it gets going, the X axis starts creeping to one side and I end up with a very sharp obtuse box instead of a rectangle..
I made sure of all my connections, cabling out of way of interference and that all the steppers were tight at the couplings..
I then switched  X and Y axis at the controller and the issue stays with the  X port on the controller, (now the Y axis is doing this instead of the X axis)
I pulled the controller open and verified that all was tight and nothing flakey looking..
I am just taking a guess that something in the board is borked (is brand new)..  There are a series of dip switches and they are all set the same..
As I am new to this, I figured there may be something I simply do not know about but it looks to me like the X axis on the controller is FUBAR..
Re: Home Setting on X axis creeping..
« Reply #1 on: May 06, 2015, 05:49:30 PM »
Might add that I had already decreased the accel/vel settings to minimal ranges..
I have a G540 sitting here but I have to convert the DIN style to DB9 on the current cables..
Another question, I do have shielded cable and have no idea what maximum recommended cable runs are (18/5)
