Hello Guest it is October 20, 2026, 05:07:43 PM
Author Topic: ESS Syil X6  (Read 7781 times)
ESS Syil X6
« on: May 05, 2015, 05:44:42 PM »
I have communication with the board since all of the flashing lights are green. I set the ip to 10.9.9.9 on entry and in the smoothstepper plugin config. I set the ip of my machine at 10.9.9.1 with 255.255.255.0 mask. I just received a virgin xml from the last owner who showed me it worked before i moved it. And nothing. Attached is the xml. What do you suggest?
Kevin
