Hello Guest it is November 22, 2026, 11:27:31 PM
Author Topic: Digitize led keeps flashing  (Read 9744 times)
« on: May 05, 2015, 06:49:15 AM »
Hello all:
I am trying to setup the tool centering and the zero plate scripts.  I am using Mach3 under windows 7 32 bit.  I have the probe on pin 13(i also tried 15) with active low.
The digitize led is for the most part off, however it randomly flashes.  I have change the debounce setting to the point where the led is mostly off, however when i run the center routine, i have the debounce settings so high that the script over shoots the contact point. Any help would be appreciated. Thanks. Steve.
Re: Digitize led keeps flashing
« Reply #1 on: May 06, 2015, 06:19:25 AM »
Had exactly the same issue. Ran grounded shielded cable to my switches / probe inputs and it fixed it. Think of the wires going to your switches as antenna. They will pick up all sorts of signals from nearby cables (steppers/spindles etc)
The way you are having to increase the debounce setting is proof of this (to me anyway)
« Reply #2 on: May 07, 2015, 11:00:17 AM »
I am looking for a good script for x and y centering.  Can you post your script?
Ed123
