Hello Guest it is October 20, 2026, 02:50:02 PM
Author Topic: Draw circle in cnc machine  (Read 9017 times)
« on: April 27, 2015, 10:55:04 AM »
I'm trying my cnc, when performed square and rectangular shapes with certain dimensions indicated in the code satisfactorily; but when making circles, this form has truncated ends, to verify if the transmission has the error I change the x and y axes, and found that no transmission problem. How I can solve this problem. See attachment thanks.
Re: Draw circle in cnc machine
« Reply #1 on: April 27, 2015, 11:20:40 AM »
Does the circle LOOK correct in the toolpath ?  IF it does then you may have a backlash problem with your machine.
« Reply #2 on: April 27, 2015, 12:10:14 PM »
I've been trying to backlash, but that value is entered or as this parameter is configured.
thanks
