Hello Guest it is November 17, 2026, 10:43:21 PM
Author Topic: Rotary axis positioning problem  (Read 7269 times)
« on: April 27, 2015, 10:17:02 AM »
I have a rotary axis controlled via a 320 gecko DC drive. I can tune it to give within a half degree accuracy on 3600 degrees rotation ( Ten rotations ). I can repeat this several times in one direction. When I command it to travel the other direction it is off by about 40 degrees ? There is less than 1/4 degree backlash in the gearing. Any ideas on where the problem would be ?
Scott
