Hello Guest it is November 22, 2026, 03:19:51 PM
Author Topic: Auto Tool Zero Script  (Read 15859 times)
« on: April 26, 2015, 02:09:08 PM »
Hey guys!  I know a lot of you have been looking for this!  Hopefully this will help some of you and I'd be happy to help you adjust it.
I DO NOT HAVE A MACHINE SO AT THE MOMENT THIS SCRIPT IS UNTESTED!!!
I'm pretty sure it will work though. I have tested everything I can in the simulator, but as the simulator does not support G31 I cannot test a few lines.  If any of you guys would want to volunteer that would be awesome.
Just copy and past the script into the button.  I have included the MCS files for the button, or if you want to use it as a macro.  If you wish to use it as a macro you will need to rename it "m10.mcs".
Do note Mach4 may seem to lock up during movement, as it's receiving the "GCodeExecuteWait" command.  That can be easily changed, but I didn't know how the "GCodeExecute" command would work on a real machine.
At any rate it should get a lot of you started on your own scripts.
Code: [Select]
AUTO TOOL ZERO FUNCTION
Author: GB Ward, Create! 2015
Rev: 0.1
Date: 4/25/15
Mach4 4.0.1, Build 2336
License:
Public Domain
References:
Mach4 Core API Version 1.01 (C:\Mach4Hobby\Docs\Mach4CoreAPI.chm)
Mach4 CNC Controller Lua Scripting Guide
Newfangled Solutions 2014
http://www.machsupport.com/wp-content/uploads/2014/05/Mach4%20Scripting%20Manual.pdf
"Motion plugin probing procedure." (C:\Mach4Hobby\Docs\probing.txt)
Down and Dirty "mcLua scripting, quick ref guide"
poppabear, Mach4 English Forums, under "Mach4 Toolbox" board.
Pound Var List - poppabear, Mach4 Forums
http://www.machsupport.com/forum/index.php?action=dlattach;topic=27396.0;attach=38035
McLua mc scripting reference - poppabear, Mach4 Forums
http://www.machsupport.com/forum/index.php?action=dlattach;topic=27141.0;attach=37937
    local mInst = 0;                                        --Sets current controller instance to 0, if running multiple controller instances, this will need to change
    local rc = 0;                                           --Clear rc
    local hSig = 0;                                         --Clear hSig
    local inst = mc.mcGetInstance(mInst);                   --Captures current instance of Mach 4
    --SETUP OF VARIABLES
    local probe = mc.ISIG_PROBE;                            --Set input here, mc.<INPUT_NAME>; input needs to be mapped in Mach4
    local strikePlateThickness = 0.060;                     --What is the thickness of the strikeplate, or how much do you want to offset 0?
    --Function to check to see if probe already grounded
    function checkProbe ()
        hSig, rc = mc.mcSignalGetHandle(inst, probe);       --Load hReg with probe state
        state = mc.mcSignalGetState(hSig);                  --Get Signal State
        if (state == 1) then                                --if hReg true ('if probe is activated then')
            return true
        else
            return false
        end
    end  --checkProbe()
    --BEGIN
    --Get current Feed rate, G90/G91, G0/G1 states to return to later.
    --Mach4 stores these variables as 'Pound Variables'
    --See Mach4 Lua Scripting Manual Page 23
    local CurrFeedRate = mc.mcCntlGetPoundVar(inst, 2134);              --Gets current Feed Rate, #var 2134
    local CurrFeedMode = mc.mcCntlGetPoundVar(inst, 4001);              --Gets current G0/G1 state, #var 4001
    local CurrPositionMode = mc.mcCntlGetPoundVar(inst, 4003);          --Gets current G90/G91 state, #var 4003
    local zProbeStrikePos = 0;                                          --clear variable
    if checkProbe() then                                                --Check probe status
        mc.mcCntlSetLastError(inst, "ERROR: Probe is already triggered.  Cannot continue.");
        do return end                                                   --"do return end" stops program.  Not sure how this works
    end --check if probe is grounded
    mc.mcAxisSetPos(inst, 2, 0);                                        --"Zero Z" (0 is x, 1 y, and so on)
    mc.mcCntlGcodeExecuteWait(inst, 'G01 G90 G31 Z-4 F4');              --G31.  Machine will stop on probe strike or go to Z-4, store in #var 5063
    local zProbeStrikePos = mc.mcCntlGetPoundVar(inst, 5063);           --Get Z strike position
    local zAxisCurrentPos = mc.mcAxisGetPos(inst, 2);                   --Get Current Z position, sometimes the probe will continue past strike point.
    local zAxisDifference = (zProbeStrikePos - ZAxisCurrentPos);        --Gets overshoot, returns positive
    local zAxisNewOffset = strikePlateThickness - zAxisDifference;      --Subracts overshoot from known thickness of strikeplate
    mc.mcAxisSetPos(inst, 2, zAxisNewOffset);                           --Sets DRO to current position
    --mc.mcAxisSetMachinePos(inst, 2, zAxisNewOffset);                  --Sets Machine to offset if anyone finds this necessary
    mc.mcCntlGcodeExecuteWait(inst, 'G00 G91 Z1');                      --Rapid move to 1 inch above current pos
    local isProbeSafe = checkProbe();                                   --Checks to see if probe is safe
    if isProbeSafe == true then
        wx.wxMessageBox("Probe is still activated!  Check to make sure probe is not damaged or still contacting strike plate.");
    else
        mc.mcCntlSetLastError(inst, "Z Axis now referenced.");
    end --if
« Last Edit: April 26, 2015, 02:16:47 PM by Gerber Baby »
Re: Auto Tool Zero Script
« Reply #1 on: April 26, 2015, 04:34:20 PM »
couple issues I fixed and documented
works in wxmach does not fully work in mach4gui have to kill process
« Reply #2 on: May 14, 2015, 10:27:39 AM »
Will this work in Mach 3?  or does someone have a code which will?  I want to program a button  on a microsoft controller
Thanks in advance
Offline dude1
  •  1,253 1,253
« Reply #3 on: May 14, 2015, 07:01:35 PM »
its M4 only
