Hello Guest it is October 24, 2026, 05:42:31 AM
Author Topic: G31.1, G31.2, G31.3 working?  (Read 21176 times)
« on: April 26, 2015, 01:03:32 PM »
I've got G31 working with my probe.  When I try to use G31.1, it still uses the same probe input although I have configured Mach4 to use a different input signal for Probe 1 which I assume is actually probe 2 as referenced in the online G Code manual, page 20, under Mach 4 Manuals.
If I try G31.2 or G31.3, I get no motion or DRO changes.
BTW, the old problem of MachGui not shutting down when Mach 4 is shut down has returned.  True, I can stop it with the task manager but it's a bit of a PITA.
What is the status of G31.X in Mach 4?
Peter
Re: G31.1, G31.2, G31.3 working?
« Reply #1 on: April 26, 2015, 01:58:04 PM »
Not sure the answer to your primary question, but MachGUI does not shut down when there is an unresolved G31.  Mine does that too.  Your options are to let the G31 finish or sometimes Reset, Enable/Disable takes care of it for me.
« Reply #2 on: April 26, 2015, 04:00:34 PM »
Thank you.  I think you just answered both questions.  G31.X is not working correctly and that causes the hangup with MachGUI on shutdown.
Peter
Offline smurph
  •  1,575 1,575
« Reply #3 on: May 29, 2015, 12:09:47 AM »
Support for the extended probe commands is motion plugin dependent.  I'm not sure who supports them yet.
Steve.
« Reply #4 on: May 29, 2015, 03:34:52 AM »
Well shoot, we can code it without G31 theoretically I think. G31 just makes life easier on us by automatically storing the coordinates in a file upon contact, then retract and incrementally jog by say 0.001, move in a pattern by same amount until contact, write to file, retract and repeat unto ~= contact while moving across a user defined coordinate plane. How did Mr. Barker do his probing video on youtube with Mach4? Bet you he just coded a script for execution or maybe that's why we only see a short video clip...I'm near done with code for auto tool setting without using G31. Well that's my intent anyways. I know tool setting is just one point. But if you succeed in accurately reproducing that coordinate over so many instances then all is needed is just to expand the code for top of material across your table to produce a file. Then...import it to Solidworks or Rhino 5 for conversion, alterations, toolpath and back to Mach for production. I know, it's sounds easy but it's not.
Offline dude1
  •  1,253 1,253
« Reply #5 on: May 29, 2015, 03:45:29 AM »
its coming soon
« Reply #6 on: May 29, 2015, 05:49:08 AM »
Brian posted a probing script on the Yahoo group either yesterday or the day before.
« Reply #7 on: May 29, 2015, 10:48:27 AM »
Thank you for the reply.  I figured since G31 was working, the motion plugin was not at fault.  Maybe it's a mapping issue.
20,000 Axes,
I'm not making a point cloud or setting tool heights.
daniellyall,
What's coming?  G31.X support or what 20,000 Axes is trying to do?
ger21,
Can't see any recent related postings by Brian on the Yahoo group.  Can you provide a pointer please?
Thanks all.
Offline dude1
  •  1,253 1,253
« Reply #8 on: May 29, 2015, 05:29:11 PM »
do a search for m400 and m401
I am not sure whats coming Brian said on yahoo group probing going to be added after hes finished lathe stuff
« Reply #9 on: May 29, 2015, 05:47:21 PM »
ger21,
Thanks all.
The posts were about point cloud probing, titled Mach4 Swap Axis on 5/26.
