Hello Guest it is November 10, 2026, 01:52:51 AM
Author Topic: Profile Shape Wizard  (Read 6227 times)
« on: April 23, 2015, 07:12:09 PM »
With Permission from poppabear, I offer up to the masses an altered version of poppbears "Profile Shapes Wizard."
to install extract the zip file to your Mach3\Addons folder.
This will create a folder called Profile Shape M.
The alterations are
Depth of Cut
added incremental cut
Define Z 0 as top of Block or Bottom of Block
And a Safe Z setting
Note that if the incements divide equaly into the Depth of cut, it may do two cuts at the same setting.
Enjoy
Wes
« Last Edit: April 23, 2015, 07:13:50 PM by ozwes007 »
