Hello Guest it is November 22, 2026, 02:29:39 PM
Author Topic: Probing with G31  (Read 17095 times)
Probing with G31
« on: April 23, 2015, 06:14:37 PM »
Hey guys.  I'm having real trouble with probing.
I'm using the simulator, and I have the probe input mapped to the ~ key.  The LED lights beside "Probe" in the Machine Diagnostics tab when I push it.  I am also able to write a short script using ISIG_PROBE which also returns true/false properly.
When I enter "G90 G01 G31 Z-4 F15" in the MDI panel or a lua script, it simply moves to Z-4 without stopping when I press the probe button.  The probe LED is lighting properly during the move, and if I hold down the probe button before executing the Gcode, I get an error that says "Probing signal active!  Cannot Continue!"
Why won't G31 stop my Z axis?
I'm not sure where I am going wrong.  I am new to both G Code and Mach 4, but have experience with programming in general.
Thanks in advance!
Re: Probing with G31
« Reply #1 on: April 23, 2015, 06:30:33 PM »
It could be that the simulator plugin doesn't support probing.
If you try to do the same thing in Mach3 without the parallel port driver, it won't work there either.
« Reply #2 on: April 23, 2015, 06:52:58 PM »
Ok, I'll stop going crazy then and build a small interface.  Thanks!
« Reply #3 on: April 23, 2015, 06:54:52 PM »
Does it do the same thing if you type this:
G90 G31 Z-4 F15
Offline dude1
  •  1,253 1,253
« Reply #4 on: April 23, 2015, 08:21:01 PM »
you can use a macro b to do probeing
Code: [Select]
G49 (Cancel TLO)
G58 (Switch to work offset G58)
G0 X0 Y0 (move the tool over the toolsetter)
G31 Z-10 F150 (probe tool down till it touches the toolsetter)
G10 L1 P1 Z#2002 (set the tool length offset value to the G58 Z position where the probe tripped)
G0 Z5 (move up to safe distance)
G54 (reapply old work offset coordinate system)
G43 H1 (apply new TLO for tool 1)
I have run it 10 times in a row and it worked fine for me.
use it at your own risk
a lua code would be better but I cant get it to work hopefully brain will relies a tool high lua code
