Hello
Guest
it is
November 23, 2026, 04:06:59 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
User DRO numbers
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: User DRO numbers (Read 14503 times)
agrotech
13
User DRO numbers
on:
April 15, 2015, 10:18:10 PM »
I have a plasma set screen with custom DROs. I am trying to figure out the UserDRO numbers for writing VB script. I found them at one time, but now I can't remember how. Any help would be appreciated.
Logged
Carnoustie, Scotland
Re: User DRO numbers
Reply #1 on:
April 16, 2015, 01:50:04 AM »
If you are asking how to find out what the DRO numbers are in your screenset then using Screen4 or MachScreen should let you see that.
Logged
agrotech
13
Reply #2 on:
April 16, 2015, 09:40:33 AM »
I tried MachScreen, I can get my screenset opened and add buttons, DROs, ect, but I couldn't figure out how to assign numbers or view the existing DRO numbers. I'll have to keep working with it till I figure out what I'm doing wrong.
Logged
Reply #3 on:
April 16, 2015, 09:43:44 AM »
Afraid I can't help with MachScreen as I don't use it. In Screen4 all you would do is double click the DRO you want and a window would pop up with all the info about that DRO.
Logged
agrotech
13
Reply #4 on:
April 16, 2015, 12:02:15 PM »
Thanks, maybe I'll try Screen4. Sounds like it might be easier.
Logged
ger21
6,295
Reply #5 on:
April 16, 2015, 12:20:28 PM »
I don't use Machscreen either, but isn't there a floating properties window? When you select the DRO, it should show the DRO #.
Logged
agrotech
13
Reply #6 on:
April 16, 2015, 08:46:21 PM »
Yeah, I found the properties window. The problem was that I wasn't double clicking the DROs.
Thanks for the help
Logged
Reply #7 on:
April 17, 2015, 06:50:56 AM »
In machscreen under Design tick Overview and you will see a listing of everything about the screen. Now if you create a spread sheet of that listing you can easily sort by DRO.
Just a thought FWIW,
Logged
Print
Pages:
1
Go Up
« previous
next »
