Hello Guest it is November 22, 2026, 08:26:21 AM
Author Topic: axis move wrong in mach 3  (Read 9761 times)
« on: April 14, 2015, 01:14:12 PM »
Hi!
Im having trubble with axis moving wrong after tuning engines, im using mm and if i set motor steps per to 320 then if I make a move G0Y0.01 the axis in mach 3 say that it stands on 0.0094 but if i move 1mm it shows 1mm.
.250 .500 .750 and 1mm show right movement in mach3.
Just cant understand why. Anyone who can help?
Re: axis move wrong in mach 3
« Reply #1 on: April 14, 2015, 02:52:53 PM »
If i change motor tuning(steps per) to 2000 as default its working as its suppose to in mach 3. but then the steps isnt right on my motors ofcourse.
Offline TPS
  •  2,627 2,627
« Reply #2 on: April 15, 2015, 02:38:40 AM »
i think it is based on your step resolution (but dont know 100%)
320 steps per mm means a resolution of 0,003125mm
Mach can only do one step, so if i does one step more:
0,0094 + 0,003125 = 0,012525 or in the other way
a move of 0.01 would be 3.2 steps
0,250 would be 8 step's and so on.
Thomas
« Reply #3 on: April 15, 2015, 07:12:30 AM »
Thanks for answer!
Yes it seems that way, and mach 3 newer goes over the given coordinate always stops one step before if it's not exactly one step.
