Hello Guest it is November 22, 2026, 08:01:51 AM
Author Topic: stepper motor sing quite a tune when move at slow feed rate  (Read 7997 times)
I am new to this but motor move well and sound good when tuning and move in axis with arrow tabs
when I load roadrunner g code to test run and set feed rate at 14 in motor sing a tune in y axis and get some vibration X axis does the same but not as bad. Is this normal with stepper
  •  9,378 9,378
Re: stepper motor sing quite a tune when move at slow feed rate
« Reply #1 on: April 13, 2015, 02:44:55 AM »
Stepper motors will sing and it is normal.
However, the volume of the singing will depend a lot on the quality of the motors and the quality of the drivers (as well as the age of the listener's ears  ;) )
