Hello Guest it is October 21, 2026, 10:52:00 AM
Author Topic: Suggestions for tool offsets and Hi  (Read 14340 times)
« on: April 20, 2007, 02:58:04 PM »
First of Id like to say Hi as I’m new to the group and then If someone could suggest the best forums to answer my Questions
The software tools I have are Auto cad 2004  Mach3 lazycam pro and the NFW
The machine I’m using /building/converting is a Clausing Kondia f1
 X and Y axis complete Z axis to do
I did a drawing of a doughnut in auto cad and then set the cut depths in lazy cam and the cut in mach 3 when the cut is done yes you guessed it’s the wrong size by the amount of the tool diameter
I have now brought lazycam pro
But before I start again Id like some help if you can
I must say that the whole software set up is great (lazycam  mach 3 ) keep up the good work
Thanks Andrew Bishop England
Re: Suggestions for tool offsets and Hi
« Reply #1 on: April 20, 2007, 03:16:26 PM »
Hi Andrew, cant really answer your question as I have not had time to mess with LazyCAM yet but there is a sub forum specifically for LazyCAM. If you dont get answers here it might be worth posting again.
« Reply #2 on: April 20, 2007, 03:28:46 PM »
thanks hood by the way the bridgeport steppers I had off you (ebay ) are working a treat thanks for your continued help
Andrew
« Reply #3 on: April 20, 2007, 03:32:47 PM »
Great, really pleased to hear they are working for you. When I got the Bridgeport I started it and jogged the axis to make sure everything worked then stripped it all out and fitted the smaller(physical size) steppers I already had.  I think I remember you saying you were going to remove the outer case from the steppers, did you do that? Also what drives are you using?
« Reply #4 on: April 21, 2007, 03:15:13 AM »
pressed of the outer case no problem  have been using the  drives from are euro trade  24 -90 volt 7.8 amp about £80 a drive
still getting things  set right  at the moment but pleased with results so far
Andrew
« Reply #5 on: April 23, 2007, 07:24:14 AM »
You willl need to offset the path in Lcam :)  We are working on making this better for you at this time
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #6 on: April 25, 2007, 02:08:39 PM »
Thanks Brian
I must say that the whole package is excellent
and thanks for  all the hard work you guys put in
Andrew  Bishop
« Reply #7 on: April 28, 2007, 09:07:26 PM »
Thank you and I have been making test cuts... so we are getting there :)
We hope to have a release at the end of the week (Hope)
www.machsupport.com
