Hello Guest it is November 23, 2026, 04:06:55 AM
Author Topic: Using a proximity sensor as a tool height setter...  (Read 8036 times)
« on: April 02, 2015, 09:02:29 PM »
I'm thinking about using a npn proximity sensor to set my tool height.
I'm using a 1.5kw spindle on a cnc router table and the tool is not grounded.
Has anyone successively done this?
Thx.
« Last Edit: April 02, 2015, 09:15:01 PM by MavStone »
« Reply #1 on: April 03, 2015, 03:10:11 AM »
What do you mean by a proximity sensor?  There are several types, magnetic, optical, etc, usually they would not be nearly accurate enough IMHO.  Much easier to have a big alligator clip with which to ground the tool when you want to set its height.  Take it off before you start the spindle!
Sent from my iPad using Tapatalk
