Hello Guest it is September 21, 2026, 04:27:51 AM
Author Topic: Can Mach3 control 3 Relay Switches?  (Read 10308 times)
« on: March 26, 2015, 02:19:57 AM »
Hello there,
I would to ask if there are some option or way to control 3 Relay switches on Mach3?
And which board I need to use?
Thanks so much!
Offline Vogavt
  •  260 260
Re: Can Mach3 control 3 Relay Switches?
« Reply #1 on: March 31, 2015, 08:36:56 AM »
Yes, you can control as many relays as you have available outputs. I use the different outputs to control flood coolant, auxiliary spindle cooling fans, etc.
Wire your outputs to the solenoid that switches the 110v on and off and then set the outputs in Mach3 accordingly.
« Reply #2 on: March 31, 2015, 08:41:36 AM »
Thanks you so much man!
I have asked this because i want to make oxy fuel under Mach3 control.
Did you use mach3 for plasma or for what kind of machine?
Offline Vogavt
  •  260 260
« Reply #3 on: March 31, 2015, 08:48:02 AM »
X2 mini mill.
MAKE Oxy Fuel? Now that's a usage of Mach3 I've never heard of.
This community continues to amaze me!
« Reply #4 on: March 31, 2015, 09:02:32 AM »
Yeah man, oxy fuel! It's your first time you hear?
