Hello Guest it is October 16, 2026, 12:26:27 AM
Author Topic: Mach 3 and MPG  (Read 21960 times)
Mach 3 and MPG
« on: March 23, 2015, 11:09:38 AM »
I am the owner of a 4 axis CNC saw that I entirely retrofitted under Mach3 (french version)
It starts to move the way I want it to...
I recently added an MPG: the UCR200 USB wireless jog pendant from CNCdrive.
It works...almost but not quite!
I followed the user manual and installed the plugin, then activated the plugin under Mach3.
Filled in the plugin parameters.
Activated MPG number 1
and it communicates OK.
downwards, I can read the DRO on the pendant screen
Upwards, I can run/stop the spindle.
But, it won't move my axis!
I have no problem moving axis using the virtual MPG of Mach3 (TAB)
Using the "settings" window of Mach3, I can see the velocity values of MPG1 changing as I turn the knob, but this is all I get...
I have found a window for MPG calibration. Any change in the values stops Mach3 with a 9991 error code.
I feel I have forgotten something somewhere...Do you have a clue?
Re: Mach 3 and MPG
« Reply #1 on: March 24, 2015, 02:05:34 PM »
Is Mach set to MPG mode?
Re: Mach 3 and MPG
« Reply #2 on: March 24, 2015, 02:59:44 PM »
Well, I would say no...
I usually use the standard run/front page, sometimes the MDI page.
How do I set the MPG mode?
Re: Mach 3 and MPG
« Reply #3 on: March 24, 2015, 03:08:08 PM »
If you press the tab key you will see what mode Mach is in Continuous, Step or MPG.
There looks to be a button on your pendant that should switch Mach to MPG mode, when you press that does the LED on the Tab screen move to MPG?
Re: Mach 3 and MPG
« Reply #4 on: March 25, 2015, 06:26:18 PM »
When I press the tab key, I get the virtual MPG.
On that MPG, I can see "lights" for the modes continuous, step and MPG.
However, none of these ever lit up.
If I click for changing the mode, continous works OK (I can change speed), step works OK (I can change step) but MPG returns nothing.
I can also change mode with my wireless pendant, but no mode will move any axis.
Re: Mach 3 and MPG
« Reply #5 on: March 27, 2015, 09:30:02 AM »
I made some progress today
I found the jog on/off button on the MDI screen.
That switches the ligths on and I can select the modes properly.
I even made my X axis to move erratically a few minutes upon turning the knob on my pendant.
Then I probably pressed the wrong button and could not move the axis any more.
I definetely need more practice...
