Hello Guest it is October 24, 2026, 03:31:04 PM
Author Topic: OLD SERVOMOTOR REUSE IN MACH3  (Read 29446 times)
« on: March 22, 2015, 04:00:20 PM »
I would like to wish to retain my old servomotors during retrofitting my heavy mazak machines.Mazak VQB 20/50 AND MAZAK SLANT TURN 40 1500 ETC.
these actuators operate with a tachometer and resolver had thought this an appropriate (modern) encoder and driver to find, so they can be controlled by eg a lab CSMIO cs / IP module A
link http://www.cs-lab.eu/en/produkt-7,2-CSMIOIPA_Ethernet_Motion_Controller__10V_6_axis_with_connectors.html
the servo would between 1.2 - 2 Kw are ...
will post some pictures of the available materials, from Mazak you should know that there is to gather enough information ... I have no wiring diagram or other data vd servomotors
like your help
thx
Re: OLD SERVOMOTOR REUSE IN MACH3
« Reply #1 on: March 23, 2015, 07:07:34 AM »
If the servo drives can accept +/- 10v then yo will almost certainly be able to use them in conjunction with the motors you have.
Regarding feedback to the IP-A , the servo drives may well have an output that simulates a 5v ttl encoder, if it does then you should have no problems. If the signal is other than 5v ttl then you could fit an encoder to either the motor or the ballscrews so that you can then feed that back to the IP-A.
« Reply #2 on: March 23, 2015, 07:14:14 AM »
You said
Mazak VQB 20/50
Is that correct? I just did a quick Google and could only find VQC
I know I have some manuals for a VQC at home that I scanned for a friend but not sure what size it was, will look this evening .
« Reply #3 on: March 24, 2015, 03:03:11 AM »
ok thx
« Reply #4 on: March 24, 2015, 03:03:20 AM »
The manuals I have are for a VQC 30/50
« Reply #5 on: March 24, 2015, 03:43:03 PM »
Hello HOOD,
I was wrong indeed ...
it should be: VQC 20 / 50B
Do you have any data on that? Or is the same old servomotors 30/50?
grtz
ps I have no manual:-(
« Reply #6 on: March 25, 2015, 04:46:59 AM »
I have no idea whether it is the same or not. I borrowed the manuals from a neighbour so that I could scan for a friend that had a VQC 20/40. I think the two machines were similar as he certainly managed to get things sorted.
« Reply #7 on: March 25, 2015, 05:10:00 PM »
Hi Hood,
how has he that DC servos then controlled with a CS LAB 0-10 volts ??
Can the manual, electrical diagram Mail
thanks in advance
grtz
« Reply #8 on: March 26, 2015, 05:09:17 AM »
No, he used the original Mazatrol control.
I have sent you a PM with some links to the pdf's on my cloud, not sure if you will manage to download or not as I have never tried before.
« Reply #9 on: March 28, 2015, 05:02:48 PM »
hi Hood,
how has that old friend then you control coupled with a CS LAB BOARD?
GRTZ
PS CLOUD = 100% OK thx
