Hello Guest it is November 12, 2026, 10:27:23 AM
Author Topic: Looking for someone who can generate code for Mach3 turn from solidworks drawing  (Read 11310 times)
Offline RFord
  •  7 7
  • Who is guarding the guards?
    • Rick's Woodworks
Hi All,
 I have a small hobby shop where I do wood parts for a couple of manufacturers.  I am using mach3 turn with a chinese lathe that was converted to CNC by Industrial Hobbies.
 I need help with generating code for my parts.   I have solidworks and can create drawings but I don't have a way to generate code.  Can someone help me generate code for my lathe???
You can check out my shop here  www.woodworks.us.com
Offline ardor
  •  130 130
Can you export your drawings as DWG or DFX?
If you can, and it works out I have a SLDPRT file that I need exported like that.
Ashby
There is no approved dental use for WD40
Offline RFord
  •  7 7
    • Rick's Woodworks
Can you save your file as a .SLDDRW file first.  It has to be in the Solidworks Drawing format before I can save it as a .DXF or .DWG file.  I can try to convert it if you want to send it to me..
Rick
Offline ardor
  •  130 130
RF
I got your PM.  Your'e email is hidden in your profile.  PM me your email and I'll send the file I have.
I don't have solidworks so I can't change it from SLDPRT to SLDDRW.
I would attach it here, but these formats aren't allowed.................YET (hint hint)
Ashby
« Last Edit: June 17, 2007, 12:42:59 AM by ardor »
