Hello Guest it is November 13, 2026, 09:41:44 AM
Author Topic: USB Controller  (Read 8488 times)
Re: USB Controller
« Reply #1 on: March 13, 2015, 05:45:50 PM »
Personally I would shy away from these boards and use something that is known to work and more importantly that you know you will get support for.
 These Chinese boards are usually a hit or miss, some work well, some do not but the one thing they all have in common is, if you have problems then you are on your own unless you can find users online who will help.
 Also if something is not right in the plugin or a feature of Mach is not supported then it is unlikely you will get it fixed.
Re: USB Controller
« Reply #2 on: March 13, 2015, 06:32:08 PM »
I changed to a laptop with no printer port, so I bought a UC-100 USB motion controller and it works really well.
