Hello Guest it is November 13, 2026, 09:43:04 AM
Author Topic: another safe Z question  (Read 7690 times)
« on: March 13, 2015, 11:07:50 AM »
After a lot of looking around I still cant find the answer that I can understand
I can ref all home   machine moves z all the way up then y to the rear of machine base then x to far right
that all works fine
then i go to 0     z goes up   x and y move to the proper set point and Z comes down to top of part
i think that is right
now i load code from Bob Cad and hit start
i want the z to go up to a safe distance above the part  but x and y start while z is at top of part   we reach the plunge spot and z will go up  and then down
to proper cut depth and runs fine
it is just the start with z down that is issue
what am i doing wrong
please show me the way to solve this
thanks
harry
Re: another safe Z question
« Reply #1 on: March 13, 2015, 11:44:55 AM »
Edit your BobCAD post processor so it does what you want. The g-code is telling the machine what to do.
